We have installed a Windows server 2012 and have been using it for more than 6 months. Now we want to monitor its performance output. Can anyone tell me how to performance monitor Windows server 2012?
Carrying Out Performance Monitor Windows Server 2012 To Get Efficiency.
First procedure: Click on start button and in the search menu search for perfmom and press enter. Then select the monitoring tools and click on performance monitor.
Second procedure: You need to right click on the reliability and performance and then select connect to a computer. Then a dialog box will appear and then enter the name of the computer to be monitored or else you can browse form the drop down list. In addition, click on ok finally.
