I have some files already written and I tried adding some new information on one of the files. When I tried to open it and write the following message appeared. I have to specify that I am using Windows XP Professional with Microsoft 2007. Can anyone please tell me how can I solve this problem?
CaseWare Template Packager
File write error. You may not have sufficient permissions to write to the
destination folder, or the current file already exists but cannot be
overwritten.
OK
CaseWare Template Packager showing error while adding some new information into files
Hi Orlando,
Seems there is an issue with authorization rights on the destination folder. Check where you are saving the file if it is inside the Program files then chances are your Operating system is limiting editability on that folder. You can move your file to a folder on your own profile. If you checked that it is under your profile try to do a right click on your root drive and then choose Properties and look for Security make sure that your user profile has full access read and write on the folder. Once done refresh Windows Installer and then try to run the program again.
