We are giving our time on an issue at our accounting firm customers’ sites where we run into the following when installing CaseWare Working Papers 2011 on a newly installed Windows 7 system:
CaseWare Working Papers 2011Â Installer Information
Error 1904. Module C:Program Files
(x86)CaseWareCWPCore.dll failed to register. HRESULT
–2147220473. Contact your support personnel.
                   OK
CaseWare Working Papers 2011 Install Errors: Error 1904
Hello Raquel,
The problem you are having seems to be quite a serious one. I stumbled upon easy solution and I hope it will help you to resolve your problem.
Before attempting this, you MUST uninstall any CaseWare software, including Working Papers 2011. After you uninstalled it, restart your machine.
If this solution doesn't work, I suggest you to call CaseWare Support.
Their support number is +1.416.867.9504. You must tell them a reference code WP-13289 for a resolution.
I wish you good luck.
