CaseWare working papers registration Wizard License Error
Hello Team,
While using caseware after sometimes I face the following error.
Can anyone tell why does this happen?
Thank you very much for the support.
caseWare working papers registration Wizard License Error – Contact Sales
Error Code: 0XC800100D
Expire License
Please contact Task Technology sales at [email protected] or +61 3 9660-4660 to renew or repurchase your license
Best Answer by Runyon Grace
Answered By 5 points N/A #146456
There could be three reasons for the License Error.
1. Your windows system clock is not up to date.
2. Version of CaseWare working paper is old
3. Your authorization code has expired
Please note that every year company issues new renewal codes.
Solution:
Update the clock
Install the latest version of software
Check the authorization code and if it has been one year old, obtain the new one
Re-register yourself.
I hope it will solve your problem.
Answered By 5 points N/A #146457
Regarding to your problem, it seems that you purchase a licensed software which is limited. Do you read the details of the software before you buy it? Try to uninstall and reinstall it again to make sure the if you have limited access or you just receive that error but it still working. If after reinstalling the software and you still encounter this kind of error I suggest to contact the dealer of this product or visit the place where you buy this.
