Casperadmin/casperinstall can mount/read from the share, but unable to write
I am using JSS 8.52 on my operating system, which is CentOS 6.2. Everything is OK, and it seems to be running fine.
You may download the code that attached below.
Result:
Casperadmin/casperinstall can both mount/read from the share, but for some reason, casperadmin can't write to it. I get a Mac authentication Popup,and the error shows – “Items can't be copied to "CasperShare" because you don't have permission to read them", when I try to mount CasperShare from a Mac using the casperadmin and want to copy over a file.
These are the screenshots:
CasperShare
Copy
Items can't copied to "CasperShare" because you don't
                              OK
Thanks in advance.
