CATALYST Install Manger has stopped working
I have running operating system Windows Vista. I had problems while installing the latest versions of the Catalyst Control Center the past 6 months, I don’t know what is meant by this error :
Microsoft Windows
Windows can check online for a solution to the problem
Problem signature:
Problem Event Name:Â Â Â Â APPCRASH
Application Name:Â Â Â Â Â Â Â Â Â Â InstallManagerApp.exe
Application Version:Â Â Â Â Â Â Â 3.0.708.0
Application Timestamp:Â 496d5b4f
Fault Module Name:Â Â Â Â Â Â Â ntdll.dll
Fault Module Version:Â Â Â Â 6.0.6001.18000
Fault Module Timestamp:Â 4791adec
Exception Code:Â Â Â Â Â Â Â Â Â Â Â Â c0000005
Exception Offset:Â Â Â Â Â Â Â Â Â Â Â 0000000000009409
So, does anyone at ATI have Vista 64 and found this error? Where is the problem with my laptop? I checked the version of C++ Re-distributable, but I got nothing. I clicked on "Check online for a solution and close the program", but I did not find any solution for the error. When I clicked on "close the program", the program closed and nothing happens.
So any help please?
