Causes Of Error Code 57 On Windows And Ways To Fix It.
My computer is running on Windows Vista. When I was trying to install some updates on my system an error message came on the screen with error code 57. How to resolve this issue safely?
Hello, the error code 57 you mentioned is mostly due to corrupted Windows support files or faulty updates. Try this method to fix your device
1) On the search button type System Restore and select it.
2) Enter the administrator password if asked and press enter.
3) Choose the latest restore point, according to the dates of updates downloaded.
4) Restore your device and save the changes
5) Reboot the system.
You can also try to clear all the junk and temporary files from the PC by clearing cache and other memory or downloads. Clearing these junk files gives a boost to your device and increases its efficiency to work.
