Hi, I suppose this started when I upgraded to the newest type, but I'm not sure of it. I am now receiving an error message notification: "CCC encountered many errors time accessing files on the inspiration or updating items on the direction" The notes say something equivalent to this "an evilness occurred spell CCC was "replacing this item on the destination" Affect "/volumes/Lacie/Applications/superduper.app/content..AND /volumes/Lacie/Applications/VLC.app/content resou…
What am I supposed to do with this kind of error? I hope anyone can give me solution for this. I thank you in advance.
CCC encountered many error messages
I think this error came from a multimedia player called VLC. But I’m also not sure about this since I only get the idea from the word VLC that I saw in the error message you posted. If this problem indeed came from the VLC player, try doing another clean installation of the application again to restore it to its default configuration and remove possible corrupted files in its installation that is possibly affecting the program from working correctly. Uninstall VLC from your machine then restart your system when asked. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install the program again after this and then do a check on it if this fixes the problem.
If you are using an older version of the player, why not try upgrading it to a much newer version. Try upgrading your version to VLC 2.0.1 which works with Windows XP [Service Pack 2], Windows Vista, and Windows 7. To download and install this version, VLC 2.0.1, you may visit VideoLAN Organization.
