CCC issues including I/O Errors
Hi experts,
I am sure this problem is same as of others. So, please help me.
I feel, this is my third complete try at a duplicate to promote from a 160 GB HD to a five hundred GB drive on a MacBook.
I believe most of the technological data about makes etc., will remain in the log file. Then, I will make it clear.
It looks to hang about 126GB.
I have been backing the files all this time and it is holding on onto one more drive. I have removed them from my foundation and will attempt to carry on backup.
That's on 12GB of files.
Basically, CCC is freezing.
Once I press on stop, sometimes I have had difficulty in continuing, attempting a variety of things, till in the end, Mac is unable to erase or reformat any drive.
It needs to be plugged into another net book, for reformatting windows, after which, it starts again on the Mac!
One or two times, it has ended due to the target address being transformed. I feel that this is because I turned it off when I went to bed last night.
So obviously, I'm not doing that at this time as well as I will make an effort to do it again. I felt, I would set this up, but there is really something in the log I am going to miss.
Really, I haven't researched about this forum a lot. Anyway, I will make out how I find on with this duplicate.
There are not enough things to do. Now I have reduced the 160 GB H drive to only 130 GB and almost 126 was done.
I need to solve this.
I need your help. Please help me.
Thanks again.
