CCleaner fails manual cleaning I am expecting suggestion’s
Posted on - 06/14/2012
Hello everyone,
I have installed the latest version of Ccleaner yesterday on my PC. I have installed it successfully, but I am facing a problem in its performance.
The Ccleaner is not cleaning the unwanted files and invalid window registry entries manually.
I uninstalled the program and then reinstalled it but the same error occurs:
Error:
Critical Error
A critical error has occurred in Ccleaner,the application must now close.
Error Description:
The thread attempted to read from or write to a virtual address for which it does not have the appropriate access
Critical Error
Error Description:
Ccleaner v3.17.1689(64-bit)
Ms Windows 7 Ultimate 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz
16,0GB RAM AMD Radeon HD 6800 Series
My computer is running on OS windows 7 ultimate SP1 64 bit and Intel core i7 2600 processor.
Is anyone else facing this issue? Please recommend what to do? I am unable to find a solution.
Looking forward to your replies
Regards
Kate
