CCleaner got “bad allocation” error using “Wipe Alternate Data Stream” preference
Hi experts.
When I tried to use CCleaner with the "Wipe Alternate Data Stream" preference,
I got the following error message:
Unexpected Error
Unexpected Error
An unexpected error has occurred in CCleaner
Error Description
bad allocation
CCleaner v3.12.1572
MS Windows XP Professional SP3
Intel Pentium 4 CPU 2.00GHZ
3.6 GB RAM
NVIDIA GeForce FX 5200
ID=-1
PR=0
DA=
RK=
RU=88
CK=0
SK=
VK=
I need to solve this error.
Need your help.
Thanks in advance.
Answered By 5 points N/A #95205
Dear Whopperman,
CCleaner, which was known as Crap Cleaner earlier was developed by Piriform, is a Utility program. It is used to clean potentially unwanted files and invalid Windows Registry entries from an operating system.
The below mentioned step should be followed in sequence to get past the issue.
Step 1:
Start CCleaner64 to clear the unwanted files. However while doing so uncheck the below mentioned entries.
  1. Firefox Internet history or IE internet history.
  2. windows log files entry.
  3. Filekey 14 in "Windows Log file" (winsys).
Unchecking these option might eliminate the crash. If the Step 1 fails, then move to Step 2.
Step 2:  Uninstall the application from the Add/Remove Program and then reinstall the same.
