Ccleaner for tablets clears all history?
Hi experts,
Have an Android Tablet that uses cleaner for tablets for cleaning the cache. Does the Ccleaner clear all history too or only clears the cache containing frequently used applications and if so can the clearing process be limited to specific data?
Best Answer by Luke N Marks
Answered By 0 points N/A #184192
By using 1 tap cleaner you can clean all caches, call logs, search history and more on default cleaner is also included. In this app 4 cleaner are included which help you to get more space by clearing cached files, navigation/search history , data files. You can list all default apps and clear the selected one.
Answered By 85 points N/A #184193
Hello
CCcleaner by default will delete any unused registry entries and history files and logs in your browser. It also cleans out your clipboard, temp files and a few other things. It will remove these files by default. You can however customize exactly what files you want to have removed. As you can see by the screenshot what options are available.
