CD and DVD Maker Not Installed Properly
Asked By 1065 points N/A Posted on -
Hello people!
This error would've made me laugh if it had  not been so frustrating. What was that 1% one about? Is there any legitimate solution to that or is it a bug? I have to admit I never saw anything like that or even expected it. Thanks for the help guys, or for any suggestions!
%1 was not installed properly, or it was altered. Please re-install the software or contact technical support.
Best Answer by Jessie M.
Answered By 0 points N/A #127868
Howdy!  This error is due to a lot of applications or programs opened. May I suggest you to follow my solutions below to be able to solve your issues:
1. Close all programs/applications and press Alt+F1
2. Create a personal password if prompted and continue
3. Create restore at the bottom of the recovery utility
4. Click reinstall Driver/Application and wait for the system to load before you click install
5. Select the version of your Window and click the application from the drop down list
6. Click the application you want to re-install (CD/DVD Maker)
7. Click the install link to run the set up and follow the screen prompts
This solution will help you fix your problem.
Jessie M.
Answered By 0 points N/A #127869
Solution 1:
You can always reinstall that program of yours and then once again try to burn your desired CD or DVD. It should work fine with no errors unless there are some issues.
Solution 2:
You can always try different types of burning software tools like the following software below:
  • MagicISO- for image file creation
  • PowerISO â€“ for image file creation
  • Nero Burner – multi-purpose burner for files and movies and sound files
  • DVD Flick – for DVD movies runnable for DVD player.
There might be one of the software that you need that is listed in here.
Don't hesitate to try this.
