I have a Samsung cd rom drive. I used to play cd’s on that drive but starting last week up to present, it won’t play any cd. Worst, there’s a loud noise on my drive. Sometimes it ejects on his own.
I can see the cd is still turning when it ejects.
Please help.
Rose sat
Cd rom is noisy and going bad
There are two reason that your CD-Rom is making noise and eject by itself. The Cd rom is making noise is because the internal system of cd rom or the hardware which operate is too dry when it roll over one another it make a kind of noise. Which is some time feel to bad. and the second is it eject by itself is that either the button through which it open is written is pressed or having problem. or the belt which make it enable to eject or insert is too lose.
you have to check it and add some kind of machine oil to it hardware the noise will be no more. and for the second problem check both these option which i discussed above. if these two problem were not found the concern to the related mechanic before you get any serial problem.
Thanks
Nazmi
It is seems that your CD Rom drive system has been disable or fully scraped. There was a button of CD Rom drive ON and EJECT. Maybe the spool of your CD Rom drive has been broken. Now it is noising. Your CD is not moving. There is no solution until you must have to repair it by a computer engineer. I think the pin of your Samsung CD Rom drive has been broken too.
You maybe click on Autoplay within your programs of default. You can establish your Autoplay selection.
Take care what would be exist in the future.
