louielamst
980 points
Posted on - 06/28/2011
I have a lot of interior designing files from all my work done. All are saved in my computer. I am afraid if ever my computer will crash, all this file will be gone.
So I decided to create a CD archive of all my files, based on some advices. I read from forums, its better to use CDBurnerXP. They told me that it runs without any problem, so I downloaded a copy of it and install at my computer. After installing it,when I run the application, and burn the files to CD, an error occurred.
I pasted below the screen shot.
Cannot continue with the burning process, because you did not select a burning device
I already selected my CD drive, Please help me locate the error. Is it with my blank CD, my CD drive, my computer or the CDBurnerXP.
James05
CDBurnerXP cannot detect my CD drive
This is one of the most common errors in CDburnerXP. Compatibility issues between your chipset, Administrative Rights, provide CD/DVD access to any user when you installing CDburnerXP. I'll give you list of solutions.
1. Uninstall your CDburnerXP. Install it again (make sure you check the all user can access it when installing). Try burning.
2. Depending on your chipset. Intel? AMD? Download the latest version (this is the common issue).
3. Check KB:929461 or try to disable the AHCI mode.
shenna22
5 points
Hi good morning
I read your issue is about burning your file and transfer it into CD. And you have encountered some error during you start the burning process. And the error goes like this Cannot continue with the burning process, because you did not select a burning device. and the best solution on that is to uninstall the driver. Or try to fine software for cdburner make sure your CDRoom used is rewritable.
Just go in this site to download ISO CDburner.
Regards;
Shenna22
