CEC_MAIN.exe Error when running Camera Assistant
Every time I run the program Camera Assistant, an error message displays that says, “CEC_MAIN.exe couldn’t execute”. I believe I should re-install the software. However, I really cannot find a solution to this issue. Can somebody help and assist me on this problem so I can use the Camera Assistant again? Thank you!
