Cell info software android applications
Where can I download Android App Cell Info Software? Is this a freeware version? Please send me the links. Thanks.
You can download the GPS and Cell Info Software for Android from the link below:
https://www.appszoom.com/android_applications/tools/gps-and-cell-info_ktsx.html
It's a freeware version.
Thanks for your post. I have already used this software. You can download this software from http://download.cnet.com/windows/ where you can also find the free version of this software. Again you can find and visit some other important sites by searching in the Google search engine.
This software only shows the one tower I'm connected to and not all the other ones around me like "Open Signal Maps" or "Google maps" does. While it's nice to know if the phone is using UMTS or HSDPA it would also be great if the frequency was displayed to show whether it's on 1600 or 1800Mhz.
So I suggest you try this software in your cell.
Thanks
Nipa
