Cellphone can’t turn on after accessing rom manager
I have an urgent problem.  My cell would not switch on. No matter what I do, I could not use it.  It started when I accessed my rom manager.  I pushed the backup rom button and then the phone turned off.  Since then, I could not turn it on.  Do you have any idea to help me so I could use my phone again?  Thanks!
Answered By 15 points N/A #105104
What specific phone model is this? It's possible that in the process of accessing the ROM manager, your phone was bricked. Have you tried charging it though? It's also likely that it just turned off simply because the battery has been drained and that it needs to get recharged. Try to reseat the battery as well, the connectors may not be properly connected hence it got turned off, but this is more of a coincidence. Try to restore your phone using the software that came with it. If it doesn't work, you may need to have it sent to a service center to have it restored.
