annelforth
30 points
Posted on - 05/22/2012
I would like to provide a lot more Central Processing Unit just a right time to host.
With vSphere àConfiguration àSoftware- System Storage Allocation àAdvanced Select host àEdit Settings …..ERROR Value of '131114 is not valid for Value
Error:
Value of `131114` is not valid for 'Value'.'Value' should be between 'Minimum' and 'Maximum'.
Parameter name: Value
Please provide resolution on this issue.
Central Processing Unit Error Value 131114
If your VMware vSphere application is not working properly, you should check its settings first. I think you are adjusting the program’s allotted disk space when the error happened. You should check first the amount of available hard disk space then adjust the program’s allotted storage space to the value that is within the range of the drive’s free space. Don’t set a value that is higher than the available free space to avoid this kind of error. Try setting another value again.
If this doesn’t work, try uninstalling the program then check your computer for any possible errors. Use a disk utility application to check the system. Install the application again afterwards.
