Centurion CC error in installing Centurion Software
When the Centurion software program was installed, it was done without proper Windows Operating System and that’s why the following error message occurs.
The ability for the software to perform auto-updates and/or access and write to necessary program directories and files may be rejected for this error. Message is:
Centurion-CC
Unable to write to C:Documents and SettingsAll UsersApplication DataDiamondCenturion CCCCSET.INI.
OK
I tried to solve it but I can't.
Need your help.
Answered By 0 points N/A #91098
Hi there Monica,
As you are having problems with Centurion software when it tries to write files it shows error. There may be some error or insufficient Parameters of permission levels if you don't have administrative access to it.
Therefore, contact your Network and/or IT specialist for gaining the proper administrative user rights which will help running the Centurion CC Software application. Windows User Rights which are Improperly configured Security settings will have an vital effect on the ability of the software to load and operate properly as it should.
