Certificate Authentication on Cisco Wireless LAN
I have Cisco Wireless LAN Controller which uses PEAP authentication. Is it possible for me to set up machine and user authentication that requires a certificate to connect in my wireless network? Can you please explain further on how to set it up correctly?
Answered By 0 points N/A #105640
try this
go to cisco acs system configuration
first enable the PEAP configuration function
now you will have to create a PEAP user/client,this is found under the user setup tab
next create a password eg.cisco
now login your cisco router,then go to WLAN,then security,then under layer 2 security change it to ****.1x
now go back to the client/user and you will have to create a new profile
this is how
go to the wireless network properties
click on the wireless tab
then click on add
under network name (SSID) type PEAP
at the top of the window click on the authentication tab
now change the wap type to PEAP
and disable "authenticate as computer"
ok>>>ok>>ok
good luck
