Certificate error message on IE
I have been logging in and out of this particular site that I use to visit, on some browsers they just do fine, but on IE sometimes this shows up and says the site’s security certificate has a problem. Is there something that I can do about it to stop this from giving this message?
I would have problems if I’m using computers in the internet cafe, because some of them only have IE and sometimes I’m caught up with this page.
Certificate Error: Navigation Blocked – Windows Internet Explorer
There is a problem with this website’s security certificate.
The security certificate presented by this website was not issued by a trusted certificate authority.
Security certificate problems may indicate an attempt to fool you or intercept any data you send to the server.
Answered By 5 points N/A #141865
Hey Desiraealexa,
You should consider doing the solutions written below:
  • First of all, check whether your computer's date and time is up to date or not. Because date and time fetch the certificate from the website server and accordingly website date tells the computer that its certificate is out dated.
  • If the problem persists, go to IE options and enable accept cookies option and make it remember browser history. Do not enter in private browsing yet.
  • If the problem persists, try opening the IE with the Administrator privileges and browse the website.
  • If the problem persists, open the website having the message and click on the add exception and now install the certificate as soon as it fetches the certificate from the server.
  • If the problem persists, you must consider a system restart and try any other browser if it works or not. If the other browsers are working normal then you should try updating your IE to the version.
Hope this will help you
