I got this weird error message using Windows XP Operating System trying to do something and failed to create the PKCS#12 backup file for unknown reasons. I am looking for the best outcomes resolving this issue. Thanks.
Certificate Manager
Alert
Failed to create the PKCS#12 backup file for unknown reasons
Certificate Export Error in Mozilla Firefox
This error occurs when you have ‘Torbutton’ add-on installed on your Firefox browser. To fix this problem, you should try to follow these steps:
1. Go to your Firefox menu, Choose Tools.
2. Then, choose Addons. Click Extension.
3. Beside the ‘Turbutton’ extension, choose disable.
I hope this information will help you to fix your problem.
Martine Paul
