Challenges In Troubleshooting Of Windows Error Bad_pool_caller
Hello, experts! Recently I am facing an issue with a windows error bad_pool_caller while I am working on ms office, I did all I can do by uninstalling the office and did a RAM, HDD check, but did not solve my issue. Thanks for your help in advance.
Answered By 0 points N/A #332106
Windows error _bad_pool_caller means your system should return to a previous configuration of your system.
Here is how you can solve the issue. Choose which suits best for you.
a. Firstly check for the device drivers update. As one or more device drivers maybe corrupted, this leads to the system crash.
b. Now enlarge the graphic card device driver, then right-click and go for properties look the version now search for the latest version on the web and download it. Later restart and start using.
c. Now open device manager and check for graphic card driver, later go for the network, then audio and click on uninstall the device. Then reboot your PC and after that, go and search for the drivers again and now update them.
d. Press start and type CMD, and allow it to run as administrator. Now type CHKDSK/f/r, follow the process and then restart, and it is solved.
e. Check for the updates in the windows update tab and install them, later restart and start using your PC. Let me know how this works for you.
