Change of auto save option
every time I go to Google or any site that has a search bar it always saves what I enter.
For example if I put it in ICC for my search the next time I put in a search that starts with that letter it always put ICC.
How can I uninstall or stop this?
Best Answer by Austin kelley
Answered By 0 points N/A #113150
Yep annoying.  It's easy.  Go to control panel – network and internet – internet properties.  Now a little window will pop up and what you do is almost all the way down in the "content" tab is a selection called Autocomplete.  Once you see that, click on settings.  The auto complete is what is filling in the browsing history on your search engine.  Once you click on the settings, you can unclick everything that you do not want auto filled.
Answered By 10 points N/A #113151
The simple solution I can suggest to you is to clear your browser history. Every browser has given provision to do this. For an example in Windows Internet Explorer you can clear your browser history by following below instructions.
Tools > Explorer Bars > History > from the panel opening in the left side you will see your browser history in the way you have selected to view (for example you can “View by Date”) right click each and every date and click Delete.
The History panel can also open by using the short cut keys of Ctrl+Shift+H
