Change caller id cm7 is not responding
I flashed CM7 RC4 a few days back. And after this, the toggle switches seem to be missing. I am not able to sync with my Facebook calendar also. I tried to change caller id cm7 didn't responded. I wonder if I have changed any settings. Can anyone help me in solving this problem?
Answered By 70 points N/A #182668
If you can't find the toggle switches anymore, try to customize the Notification Power Widget. Just click on Start and then go to Menu. Click on Settings and then click on CyanogenMod Settings. Go to Interface and then click on the Notification Power Widget and modify it accordingly. Remember to reboot when you applied any theme as this Notification Power Widget will not be visible when you changed your theme unless you reboot.
For the Caller ID issue, try a reboot also. Also, ensure that her phone number is listed in (123) 456 7890 format. Or you can also get the Go Contacts in the market. This should help you fix your issue with the caller ID.
