path5nder
200 points
Posted on - 04/21/2011
Hi everybody,
I need a small support, I have a big Paragraph which is typed in small letter so please let me know is there any methods to change them all into "ALL CAPS" or do I have to type them back?
blogerq8
Change the font of entire paragraph to ALL CAPS
Select Your Paragraph and Press Shift + F3 you are done. You can use this shortcut combination of keys to change from CAPITAL LETTERS to simple letters and simple to CAPITAL LETTERS or to Title Case.
Regards.
Thanks dear. Appreciate your kind support. Its working but how we can use this by using menu bar?
blogerq8
To do this manually, Go to Main Menu – Select "Formats" – Select "Chance case" then one small box will be appeared as shown below from this you can use any of the options.
Wow! That's great! You pasted the exact windows on this reply. Thanks for the information dear.
blogerq8
Yes I pasted the exact windows because it will explain more than we type. And also it's very simple. You can take any of your windows / image which is on your screen and if you like to get more information about this, just follow the below mentioned link as I saw one thread in a techyv website about screening capture. Hope this would useful for you since you don't have an idea about this.
Yeah that's great. I went through that thread and it clearly explains about the screen capture subject. As I understood, there are two methods to capture, one is to capture the entire screen and another is to capture only the active windows. Anyhow, thanks for sharing this with me and I hope that I can forward this link to my friends as they'll be happy to get to know about this.
dipok
200 points
Select the paragraph first then press Shift+F3.
