Change iPHONE keyboard to different language
I want to get some different languages to be typed in my emails or SMS
Where can i make this settings change and can i have exact steps with images
Unlike physical keyboards, you can change the format of a software keyboard, including the dictionary used for auto-correction, the number of letters, and the arrangement of the keys (for languages with alternative keyboard layouts).
You can select different keyboards from Settings > General > Keyboard > Keyboards.
iOS also allows you to choose hardware keyboard layouts to match the keys on your physical keyboard.
If more than one keyboard is on, you can change the language while typing with two methods:
