Change Language in Opera Mini Application
Hello Erni Fitri,
I want to believe that you are talking about your opera mini phone application and not the PC browser but nevertheless,I will provide you with a solution for both. Okay,when downloading Opera Mini to your phone make sure it is in a language version you understand since the language version is chosen before downloading from the opera mini website.
As for the PC version,you can always change from search engine page for instance. ''Google in English" that's usually below the webpage or slightly below the Google search 'input 'area.
I am also using Opera Mini before when it was still free to use mobile internet. But that was before and now every seconds count on the speedy bill. Since it was already too long to remember how my Opera Mini works and mine was already set to English that’s why I didn’t mind checking it, I found something on the web that describes how to change the language.
To actually change the language set in your Opera Mini, open the application from your phone then press # then 8. Go down where you see something like “Norsk” or maybe something different. Change this language to “English” then save it by pressing the left soft key.
