Change parental settings on ps3
You can try doing this:
NOTE: Usually the default password is 0000.
Change the password required to adjust system settings. Why do you need the password?
· When playing content with parental control restrictions
· When changing the system's parental control level or Internet Browser Start Control setting
· When starting the browser with the Internet Browser Start Control setting set to [On].
· When changing the current password
HOW TO REVERT YOUR PASSWORD BACK TO [0000]
ON YOUR SYSTEM GO TO: SETTINGS > SECURITY SETTINGS> RESTORE DEFAULT SETTINGS.
All other settings will also be restored to their default values
If you want to change the parental controls take note of the following levels of restriction:
Level 1 – 11: The lower the value the tighter the restriction.
Off : No Parental Controls, users can play any games
ON YOUR SYSTEM GO TO: SETTINGS > SECURITY SETTINGS> PARENTAL CONTROLS
You can also take note of the BD/DVD PARENTAL CONTROLS and BD/DVD PARENTAL CONTROL REGION CODE just in case you are having problems playing your games.
In PS3 or PlayStation 3, by default, all parental controls are set to OFF. All modern video game consoles have parental controls that will help you determine what content your children have access to while playing games or using any of the other features on the console. If you have enabled the parental controls, you need your password to be able to reset or disable the parental control restrictions you set.
In PlayStation 3, go to the Settings of the main menu. Then select Security Settings and then enter your password. The default password is “0000” if ever you haven’t changed it. Next, select Restore Default Settings. At this point, you have to enter your password again to continue. For other information on how to reset the parental controls on other game consoles, you may visit How to Reset Parental Controls on PS3.
