Change the path of the archive folder in Domino web access?
Is there any way to change the path of the archive folder in Domino web access? Domino web access has been configured and the active x plug in is also changed according to Domino sync Manager. From DWA > Preferences > Archive section.
Then it shows error message. I need this to be done soon.
Please help me.
Answered By 55 points N/A #100182
Normally users do not need to set this path for the archive folder by themselves because it is defined at the software level and is automatically handled by it. So what you can do is
Open the notes.net forum. There are few times when there is a bug in the Domino web access that the profile that is being used becomes unreadable and so the archive profile is not accessible by the notes. You can also rename the file up to 6 characters.
However you have successfully made the archive then just modify it so that it does not becomes unreadable. Also the database usually tends to use the new instance of the domino web access so that is why it is not getting the response correctly.
