I have FIFA 12 game platform installed on my PC, but we have been trying to increase the graphic sharpness for a better view without much success. I have really tried with the help of my friends, but no one seems familiar with graphic settings of the game platform . How do i change the sharpness of FIFA 12 anyone?
Hi You asked for the process to change screen resolution in fifa 2012 game. You may find it difficult because of the settings are not of so called normal in this game. Follow the following process:
Go to this FIFA 12 Game folder.
Go to the fifasetup folder.
Click on fifa config.exe. A window shall open.
Go to game display settings.
Change the screen sharpness.
This is a easy process. Hope you can do that easily now.
If you play FIFA 12 and you want to improve the graphics quality of the game, the key is in your video card. First, you need to identify which video card you are using. If you are using NVIDIA, click “Start”, “Control Panel” then select “NVIDIA Control Panel”. Another way is to right-click an empty spot on your desktop and select “NVIDIA Control Panel” in the context menu.
FIFA 12
In the NVIDIA Control Panel, search for an option like “3D Settings” or “Application Settings” then open it. Here, in “Select a program to customize” (if you have this), select the application or “FIFA 12” from the dropdown list or click “Add” then select the game. Now, configure the application or the game with the following settings:
Anisotropic filtering – 16x
Antialiasing – FXAA – On
Antialiasing – Mode – Enhance the application setting
Antialiasing – Setting – 16xQ CSAA or 32x
Texture filtering – Quality – High Quality
Texture filtering – Anisotropic Sample optimization – Off
Vertical Sync – On
Before applying these settings, verify that your video card has at least 1 GB video RAM to render this much.
1....
