Change the Time of my computer failed.
I am trying to change the time of my computer, but it says that you have no proper authority to change the Time.
How I can change the time of my computer.
Hello Dear,
It is very easy to understand. Dear your administrator has disabled the authorities of your account.
Or you are using a guest account, so that you are unable to change the time.
Restart your computer, when it comes again to the logon screen. Press CTRL+ALT+Del keys twice.
Now a username and password dialog box will appear.
Type Administrator in username box and press enter. Now the computer is logged on as administrator account.
Now you can made changes as you want.
Thanks
