Is it possible to change the voice of a person so that it can sound different? Moreover, are there any proprietary solutions involved? Besides that, I would also like to know the answer to verify if my voice has been tampered with.
Thank you.
Change the voice of a person so that it can sound different
Yes dear, it is a common feature available on most of the advanced mobile phone. You can change your voice and it will sound different. Make a joke with your friends because it not only change voice but also change voice from male to young girl and female to boy. Try to set it from your phone. Look through your phone if there is a pitch volume option. Also you can phone a number for trial and go to option when you are on a call. Check there are some options and pick one option that is related to voice changing. It will be default for next calls.
