Benj Parker
200 points
Posted on - 07/18/2011
Hi to all the readers,
I am using an HP machine and it is running on Windows XP Service Pack 2. There is an issue with my power options. I tried to set and change the power options, but it does not take effect. I did the usual refreshing of the machine and tried it again but to no avail.
Looking back, I believe there is a security update which was installed on this computer before this happened. In addition, I do not know if the security update is more important than that of my power option issue. I hope someone can suggest a better option for me to have the update and my power options working both at the same time.
Seabert
Changes in power options would not take effect
This is can be configured with error free settings for the power option, just go through the following instruction as guided which helps to uninterrupted remotely managing option for both the desktop and laptop. To do the same juts go to the properties >> right click on the desktop and go to the properties, >> select the Screen Saver tab which is just the third tab you can find from the right side from the left, >> select the power button which just below of the power monitor section, than you select the desired any option which related to the computer machine.
Hello dear,
If you are sure that you have installed a security application, first you have to check the application, that's why this problem is occurring. Change the power options and settings as you want, and they will show the effects as well. Just choose Properties on the desktop and choose Screen Saver. On the lower area of the screen saver tab, you will see a power button in front of the Energy Star logo. Just click on it, then you will see this window.
Just make changes as you desire to your power scheme, and click apply and then ok.Â
