Hi guys,
How to change green color folder icon? I want to switch it to other color so that I can easily identify my folders from my business, personal folders, movies and more. I am confused on the color and icons that I placed before, so I have to organize it now. My current Os is Windows Xp.
Expecting some help, thank you.
Changing the color of the folder’s icon in Windows XP
Hi Isabella,
                Well first of all Right click o the folder and then go to Properties in the drop down menu, after that select Customize tab in it, now click on CHANGE ICON BUTTON and there select the Icon and the colour you want for your folder and after selecting click on OK and the APPLY and you're all set. Also you can download a utility called FOLDER MARKER in order to change the colours of your folders without any hassle. Here's the link to download Folder Marker, just download it and see the magic.
http://foldermarker.com/en/download/
Hope this resolves your issue.
Regards
