Changing the drive letter of a disk drive.
OK then you can change the letter “H” to “K” but remember that you can’t do this if you have any hard drive or any partition that already named “K” other thing is that you can’t change the letter ‘H’ to A,B,C. Now I explain in some steps for the windows XP users. First go to the control panel then go to the administrator tools, you will see “computer management” now open it. Open disk management, find out your drive and right click on it and click on “change drive letter and path. That’s it you reach to the station. Good bye.
Hello Stepanjohn,
To change your drive letter for the DVD to another, you just use the disk management utility. You can access disk management using the following simple procedure:
You will have successfully changed your DVD drive letter paths.
__
Regards
Lee Hung
