Changing the email address registered in my account .
Is it possible for me to change my email address in my account without registering again to create a new one?
Hi Katherine,
It can’t be possible to change an email add in your account as far as I know you can add an alternate email in your account but it depends what type of account you use. Only User Id or User Name can be changed. You probably to create a new one if you want to change your email add.
Best regards.
Hi Katherine,
If you are referring to changing email on your TechyV account, yes it is possible. I’ve tried changing my email address and it worked. To change the email, just hover your mouse on “My Account” located on the upper right part of the page. A drop-down box will appear and click on “Edit Profile”.
Now on the “Account Information” tab, just go ahead and change your email address and hit save. And that’s it. You should be good to go.
Hope this helps you.
