Changing fifa manager 2006 wrong language
I have noticed there is fifa manager 2006 wrong language when I play it on pc. Where to take language pack to change languages on which I need?
Hello.
There are many websites available which provide fifa manager 2006 language pack.
These websites provide you fifa manager 2006 language pack for free.
After a quick research I found a website which provides English language patch for fifa manager 2006.
Click on the below link to download English language patch for fifa manager 2006.
http://www.gamefront.com/files/4742661/FIFA_Manager_06_v1_2_English_Patch
Thank you.
Hi Desiraealexa,
The language change tool can be downloaded from the Ausgamers Official website
There are multiple solutions to solve the problem.
Solution 1: Change the game language through settings
The steps to be performed for change in language are as follows:
1) Run the game
2) From the main menu, select 'Preferences'
3) Under the game settings tab, set the game to the specific language
Solution 2: Set the language of Steam client
1) Launch Steam
2) In the top left menu, select 'Stream' > 'Settings'
3) Select the 'Interface' tab and change the language
4) Click 'OK'
5) Select 'Restart Stream' to start the stream process
