Changing the language and ipod apple shortcut alt key
Hi experts, Please inform if the function of iPod apple shortcut alt key is affected after shifting from English to French let's say. Thank you
The iPod is a multilingual and can be set to display and use one of the many languages it supports. If you’ve accidentally chosen the wrong language for your device, by simply resetting the iPod may cause it to forget the present language it is set on. But I think this also depends on how much you’ve used the device since after the wrong language was selected. Visit Apple — How to reset iPod for the guide on how to properly reset the iPod.
When resetting the iPod, always disconnect it from the computer. But if it is presently connected to iTunes, you should eject the iPod from within iTunes instead of resetting it. See also Apple — iPod: Changing the display language for other important information about changing the language of the device.
