20 points
Posted on - 04/07/2012
Changing the Photoshop’s default magnification
Hello Techyv user,
By default you cant change the magnification of image in adobe photoshop. You can magnify the image by using the option called 'Fit to screen'. This option enables you to magnify the image to fit according to the screen size. That means you can view the image without any magnification / You can view the image in 100% zoom.
Thank you.
Hi, Denver Howell
The Adobe Photoshop currently has got no method to change the default resolution when opening a new file. However, when the file is opened once, the user can always press Ctrl and the minus key to zoom in on the image.
This is an option applicable with all Photoshop versions. Please try this option.
Thanks and regards,
Skarbos Jay.
