What is the way to change the speed of double click of Mouse in Windows 7?
Changing the speed of the Mouse
First go to “My computer”, then Click the “Open control panel”, then change view category by clicking “View by” option and change it into “Large icons”, then find the “Mouse” icon and click it, then go to the “Pointer option” and click it, then “Select a pointer speed” move it to ”Fast” site and your mouse will be fast .
Select a pointer speed” option can control your mouse speeds.
Click start, go to control panel, click, then go to the mouse, or in some cases you may need to go to hardware and under the drop down tab you find the mouse, then you click on mouse and you then look for buttons, you click on the speed you want, that is your double speed. when you finished making your changes click apply then ok, and your mouse will take full changes in effect.
