Changing windows 7 start up mp3 to a downloaded mp3 choice
How am I supposed to change my windows 7 start up mp3 to an mp3 version I downloaded and still maintain the other Windows 7 default tunes?
Hi Janice,
               Windows 7 startup mp3 is the default applications of the windows 7 startup operating system. To resolve this problem, you need to change your Operating system to enterprise or professional. When you change the operating system, the mp3 also automatically change. Bring the unit to authorize service center, and ask to change the operating system.
ThanksÂ
The start-up sound of windows 7 is a built in sound you could not change it, you may make it silent but could not change it, But there is another thing called long on sound you can change it easily and legally. And one more thing this thing is not related to your windows version.
Make certain that the new seem you are likely to use is usually formatted to be a WAV report considering that music data will never operate. In case you have a new. wav seem report you would like to add, and it is not really too big. Be sure to allow the item a unique name which means you never over-write a current report.
You'll be able to utilize the Audio discussion inside the Command Screen to select just what action you choose your seem pertaining to, subsequently "Browse" compared to that seem. In reality the item appears like of which 'browse' signifies you don't need to find your seem. wav report as folder, but spend less the item everywhere.
