Charging Laptop batteries more efficiently
What will happen to the battery of my laptop if it is not fully discharged before I start recharging it? Will this approach affect the efficiency of the laptop battery in any way? Do you have to charge the battery fully to 100% before using it or it is ok to stop charging before it reaches the 100% fully-charged state? Is there a downside to using a laptop with full battery capacity while having the AC charger plugged in? Does this affect the battery quality?
