Ethan_H
Posted on - 09/15/2011
For 2 days now, my 4-year-old Asus motherboard shows this error on boot:
Chassis intruded!
Fatal error…System Halted
I do not know what seems to be the problem. Is my motherboard going bad?
Could it be one of the attached devices?
I need help. Thank you in advance for any suggestions.
Chassis intruded! Fatal error. System Halted
Hello Ethan.
Some motherboards have a feature for detecting when the CPU chassis has been opened.
That feature is used for CPU chassis that have chassis intrusion switch such as the one shown below:
You didn't say whether you have a chassis intrusion switch or not. If you do have a chassis intrusion switch and you have it connected to your motherboard, you will have to reset it. The tutorial on this site will explain how to reset the switch.
On the other hand, if you never had an intrusion switch installed in the first place, then you should disable it in the BIOS options. See your motherboard manual for details on how to do that.
Hi
Regarding on this issue there is another Techyv post which one will be also helpful for you to fix this isseu.
For more information visit this link : Chassis Intruded Fatal Error on Windows XP
