Cheap bt good Jquery mirror slider Plugins for WordPress themes.
In need of cheap but good jquery mirror slider plugins to be used in my responsive wordPress themes and one which can stretch to fullscreen.
Kindly download vslider-wordpress image slider plug-in. Vslider is jquery based plug-in. You don’t need to have any coding knowledge for applying vslider-wordpress image slider. You can download the vslider 3.0 wordpress plugin, vslider 3.1 wordpress plugin and vslider 4.0 wordpress plugin. You have to unzip the v slider plugin and upload it in wp-content/plugins/ folder. Now try to implement this in your wordpress website.
Regards
There is a plugin called FlexSlider from WooThemes. Its a fully responsive jquery slider plugin, it also resizes according to the screen on which it gets displayed. It supports all major browsers, and you can use it for horizontal or vertical sliders.
FlexSlider supports the latest version of jQuery, and moreover it has the touch swipe function for touch phones and tablets.
Hope you like the information,
Cheers !!!
Notifications
