Cheap true-rated 500W-550W power supply
Can you suggest a cheap true rated power supply just around 500W-550W?
I only need one for my low specification desktop computer at home.
I would recommend " Kingwin Lazer Platinum 550w ".
It has maximum cooling experience and noise is minimized.
It has very high end GPU performance.
For its technical specification please visit:
For list of other Power supplies:
As you just need the power supply for your desktop computer " Kingwin Lazer Platinum 550w " should serve the purpose.
Hope this helps.
Hi Onemig,
Compare to Kingwin Lazer Platinum 550w, Antec 550w ATX power
supply would be a better product for you.
It is only $ 49.99 compare to the above mentioned which
price is $173.99, which is obviously cheaper.
For more information about the power supply, try to visit
this URL where I found this power supply:
