Check battery wear level for android
Has there been any software to check the battery wear level for android. If any then suggest me which one is the best.
Hi Adityasaklani,
There are n number of software to check the battery level in Android mobile. Normally you will find all this software in Google play store in your android operating system.
One of the software is Bataria. If you want this to download enter the name of the software in Google store and click download the download starts.
There are many software’s to check the battery for android phone:
If you want an app that can check the status of your battery, try downloading GSam Battery Monitor on Google Play store. If your battery is draining too quickly, this app will help you find out why this is happening. With GSam Battery Monitor, you will find these features handy:
