Hi Experts!
I want to create my own domain and I'm seeking for an expert's advice on how to create the best and unique domain name. Please tell me what are the necessary things that I need to consider in creating domain name and how will I make it unique? Where will I go to check domain title for errors and to avoid duplicates? Also, please tell us the best place to get a domain name considering the cost and the services of the webhosting domain. I will be waiting for your advice.
Thanks in advance.
Allison Ward
Check Domain Title for Errors and Duplicates?
Hi dear Allison ward,
According to your question named "how to create the best and unique domain name", i am going to give some suggestion .
Keep the name as short as possible
Avoid copyright
Makes it easy to remember
Make it easy on type
Make it attractive
Only choose dot com domain
Reject hyphens and numbers
Do not follow the latest trends
To check the website i recommend you the following sites-
For domain name-
Use checkdomain from any wireless device
Instant domain search-
Instant Domain Search HomeFAQArticles
For DNS health please see-
DNS health check
To buy a domain the following site is best rather than any other.
Go Daddy Global
