alex baker
30 points
Posted on - 06/01/2012
Thanks to ASUS for bringing the New EEE Pad Transformer Prime with its Nvidia Tegra 3 quad core processor and a 12-hour efficiency Li-composed battery, are the features of this new gadget includes Bluetooth connectivity?
Check Out The Latest ASUS EEE Pad Transformer Prime
Hello Alex! Yes the Asus EEE Pad Transformer Prime comes with Bluetooth 2.1 and 802.11 b/g/n (Wi-Fi). The Prime has 1GB of RAM and you have the option to either get the 32GB or 64GB variety. The display is a 10.1 inch LED backlit screen with Super IPS (Super In Plane Switching – which means it has a wider viewing angle with minimal color shift). It has a resolution of 1280×800 and the protection of Corning Gorilla Glass. The 8MP camera at the back takes great pictures. It comes with Android 3.2 Honeycomb but is upgradeable to Ice Cream Sandwich. It is also thinner than the iPad2 and the Galaxy Tab 10.1. It is also the first tablet to use the Quadcore Nvidia Tegra 3 but unfortunately not all games make use of these feature and as a result the frame rates may suffer.
